TSSA
TSSA
Would someone be able to tell me if CRN Numbers are required for all components on a skid or is it just the pipe and piping fittings?
Have a package whos' design needs to be TSSA certified.
RE: TSSA
If this piping assembly needs to meet the pressure piping code requirements in Ontario, and is being assembled here then it'll need to have its' design & spec registered with the TSSA, be assembled by an authorized shop, and they'll have to witness the pressure test. If it's coming in from outside of the province (assembled in another jurisdiction), I'm not sure what needs to done, but I'd check into it before I ordered anything.
RE: TSSA
RE: TSSA
RE: TSSA
RE: TSSA
Thank you sir!!!!!!!
RE: TSSA
RE: TSSA
Someone once wrote what they thought the letters "ASME" stood for - "always, sometimes, maybe, except".
RE: TSSA
RE: TSSA
RE: TSSA
Here is my useful site for CRN number and requirements.
http://www.pveng.com/Reg/Reg.htm#QF
CRN numbers apply (differently) to pressure vessels (over 14.7 psi?) and fittings (including valves and instruments sometimes).
If your supplier does not have a CRN number for your province, he may be willing to apply for one (business decision). You can always ask.
RE: TSSA
