Aluminium Peel Shim
Aluminium Peel Shim
Hi guys,
I am wondering if some of you have the approximate value of the compression modulus of an aluminium peel shim. Really, I am going to fill in some gaps with these shims and I am going to take into account their deformation under preload since they seem quite flexible.
Best regards,
Franck
Best regards,
Franck
RE: Aluminium Peel Shim
I suspect that the value would be somewhat less than that for the aluminum material itself, to account for whatever the stick-it-together stuff is.
If it is important enough for you to take it into account, then it is important enough to test it yourself.
