Keeping RecordSet Open
In my program, I am setting a RecordSet(RS) Source. Then I open the RS, and load the frist 25 records into my form. All that works okay. I have a Next button on there, and when I click it, the RS isn't open anymore, and it dies.
I'm not closing the RS or setting it to nothing or nil. From one Public Sub to another, shouldn't it stay "open", or am I missing something?
TIA
TIA
RE: Keeping RecordSet Open
Cheers,
Joerd
You didn't mention how you retrieved the first 25 records, if you've done it with an SQL statement like: "SELECT TOP 25 * FROM ..." you'll just need to rerun your SQL statement again - in other words, you'll need to close the recordset, and then reopen it again.
HTH
Todd
Dim RS as New ADODB.Object
I had to have the "New" in there, else it didn't work as expected. I did use a SQL statement like mentioned. When I reran the SQL statement, it didn't know what RS was, so I had to redim it, and Open the RS again.
The recordset isn't closed, it just doesn't contain anymore than 25 records. You shouldn't have to redim RS though. So somewhere above your modules in the General area of your code, change:
CODE
CODE
You may also try:
CODE
HTH
Todd
Good Luck
johnwm
________________________________________________________
To get the best from these forums read FAQ731-376 before posting
Steam Engine enthusiasts: www.essexsteam.co.uk
Public RS As New ADODB.Recordset
When the routine that starts filling a table runs, I get a message, and all it says is "Catastrophic Failure".
So if the Dim statement isn't in the routine, it won't work. I currently Dim it right before I do a RS.Source = "Select * FROM Table", and then a Call RS.Open......
==> In my General Declarations, I used: Public RS As New ADODB.Recordset
==> I currently Dim it right before I do a RS.Source = "Select * FROM Table", and then a Call RS.Open.
That second one cannot be in the general declartions, so if you're doing both, you have two different recordsets in play, each with a different scope, and although it's legal, it can be very confusing.
Good Luck
As a circle of light increases so does the circumference of darkness around it. - Albert Einstein
It looks very simple, but it doesn't work. Frustrating
Sounds like you need to declare the RS in the general declarations section, but without the 'new', because you use it in several different sub. You need to allocate it when necessary, possibly in the Form_Load event, manage it during the run, and finally close and release it, possibly in the Form_Unload event, when you're done.
Good Luck
