Hydrocarbon dewpoint (HDP)
Does anyone know a method that can be used to calculated the HDP knowing the compostion of a natural gas.
athomas236
athomas236
Hydrocarbon dewpoint (HDP)Hydrocarbon dewpoint (HDP)(OP)
Thanks athomas236 Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: Hydrocarbon dewpoint (HDP)
The y fraction are the mol fractions for your gas composition.
You then estimate a temperature, read off the y/x ratios for each component and then calculate x (the mol fraction for each component in the liquid phase) for each component. At the dewpoint, the sum of your x fractions will add up to 1.0 (or sufficiently close). If the sum of x doesn't add up to 1.0, you pick a new temperature and repeat.
The heaviest components have the biggest effect on dew-point and are the most difficult to accurately measure. I'm always suspicious of calculated dewpoints unless I can translate them back to another point in the process and verify that the calculated dewpoint is reasonable.
You did not indicate the operating pressure. Generally the higher operating pressures require more difficult calculations.
I agree with TD2K about the accuracy of dew point calculations.
There are two manufacturers of hydrocarbon dew point analyzers that I know of: Michel and Ametek.
Will this work?
Thank you for you advice.
I want to make calculations at the design stage for natural gases up to 70 bar.
Any other suggestions for appropriate text books or software would be appreciated.
Have a good Christmas
athomas236
Nowadays, almost every engineering company,(petro)chemical company, oil refinery, Gas plant, you name it, use some sort of simulation program. If you are working for a company working in these areas, certainly for gas industry, your company must have at least one license of such a simulation program! The most used simulation programs are Pro/II and Hysys. If you have access to these softwares, then it takes 5 minutes to determine the dew point at your operating pressure!
Otherwise you have to look into books like perry and/or other useful books like other poeple have suggested
Good luck.
Thanks for advice.
My problem is that at 60 years of age I have got used to understanding theory rather than just running a program.
As a company we do have Hysys, I could just make a phone call and get the answer but I would still not have any understanding.
Too many of our younger engineers would rather walk around the office asking for a spreadsheet or whatever rather than open a book.
Sorry but sometimes these things touch a nerve.
Have a good holiday.
athomas236
I have just given you last posting a well-deserved star. I agree with you 100 percent and I applaud you for having said what you did about using spreadsheets or simulators without understanding the theory!!
I will be 83 next week ... do you think that may have some correlation with my applauding your statement??
Seasons greetings to all!
Milton Beychok
(Visit me at www.air-dispersion.com)
Cheers.....
Calculating the cricondentherm temperature requires doing phase equilibrium calculations (bubble pressures at gradually increasing temperatures) until you reach the cricondentherm temperature. At this point, the curve swings back toward the critical point. Then you are in the liquid region, following the curve further will take you to the cricondenbar pressure, and so on.
Unfortunately, bubble pressure calculations become progressively harder to converge as the system approaches the cricondentherm temperature. I can personally attest to this fact, having spent considerable effort on the problem myself many years ago.
This has been an area of considerable research (Heidemann and Khalil, Michelsen). Their algorithms are both very reliable and fast, and have been encoded in the major process simulators, as mentioned by Homayun in this thread. That is why the most practical solution is to use a commercial package - most engineers do not have the required chemical engineering knowledge, mathematical training, and programming skill to implement, for example, Michelsen's algorithm themselves on a computer. Also, it is virtually impossible to do this calculation by hand, as a horrendous amount of iteration is involved, no matter which equation of state you use to describe the underlying thermodynamics.
Finally, I would also say the "answer" is by no means unique: it depends on the chosen equation of state and, further, on the binary interaction parameters chosen. In addition, the accuracy of the measurement for the heavy ends is crucial. Very small amounts of heavy ends (1 mole percent or even less) can affect the cricondentherm temperature by 10 deg. F or more. Equally unfortunately, the accurate analysis of the C6+ fraction requires very careful chromatographic analysis by skilled analysts using well-calibrated gas chromatographs.
These are some of the reasons why this is a continuing area of concern in the gas industry. Each gas mixture has its own (very difficult to measure, as Dick Russell has stated) unique dew point. The computerized calculation methods should be regarded only as an approximation to the truth. For this reason, most gas supply contracts specify the calculation method to be used (e.g., Peng-Robinson equation of state with specified interaction parameters for all binary pairs).
The fundamentals of these calculations are described by Daubert in "Chemical Engineering Thermodynamics" (McGraw-Hill, 1985). For the best numerical techniques, you'll have to consult Michelsen's papers in the journal Fluid Phase Equilibria (circa 1985).
Gentlemen,
Thanks for all the advice.
The reason I started this thread was to gain an understanding of the methods of calculating HCDs. It is simple for me to obtain HCDs from our own chemical engineers who simply run the Hysys program, but that adds nothing to my understanding.
From the responses above there appears to be a relatively simple method as described by TD2K (and I intend to order the book "The Properties of Gases & Liquids" by Reid, etal as sugested by srfish) and more complicated methods that involves equations of state and the convergence problems mentioned by UmesMathur.
I expect that the more complicated methods are most accurate and hence most appropriate in a professional chemical environment. My concern is that the complexity could hinder my understanding.
At the moment, I am struggling to understand why I need to get involved with equations of state (and fugacities and fugacity coefficients, mentioned on the internet) if equilibrium valves y/x are available for components from C1 to C6+ for thr ranges of pressure and temperatures I need.
I have searched the internet for equilibrium valves y/x but so far without success. I, however, have found a software package ALLPROPS that will give me fugacity coefficients
which appear to be the values of y/x divided by the total system pressure.
I will continue my search for equilibrium valves y/x for components from C1 to C6+. If unsuccesful, I will probably derive them from the ALLPROP fugacity coefficients and then make calculations as suggested by TD2K.
If anyone can see flaws in this approach I would welcome any comments.
Best regards,
athomas236
The "K" values (y/x) for such systems are the ratios of liquid to vapor fugacity coefficients, which are generally returned from a routine calculating them as a function of temperature, pressure, and composition as f/py or f/px. Especially at high pressures, there is some composition-dependency. Since at equilibrium the vapor and liquid fugacities are equal, and the pressure is the same of course, then the K value = y/x = (f/px)/(f/py). Clearly, some iteration is in order. A dew point calculation procedure in a flash program will start out with some estimate of temperature and either phase compositions or K values, make two calls for the sets of fugacity coefficients, divide for the K values, and get the summation of x=y/K. If the sum is not essentially 1.0, iteration is in order. Temperature must be found so as to satisfy the sum of x=1.0, and the calculated x must be plugged back into the fugacity calculation to refine the K values used in the summation of x. That is a double iteration, and the techniques for doing it efficiently and robustly vary from one package to another; it's a whole different subject by itself. If you are doing this by hand, you may get a decent approximation of the DP temperature by assuming that the composition-dependency is not too great. That reduces the problem to finding just the temperature that gives the sum of x=1.
Many of the common quations of state for hydrocarbons, such as Soave, Peng-Robinson, and over 100 other derivatives of the original Redlich-Kwong EOS, use cubic or other expressions for phase density, and multiple roots exist. The appropriate root is selected according to phase. If the system is above the cricondenbar, you can't have distinct phases, and the calculations collapse toward fugacity coefficients being the same for "both phases," the K values go to 1.0, and there really isn't an answer. Sometimes a valid answer exists, but the starting point in the calculations ends in failure and perhaps the wrong conclusion about whether there is an answer. This is where the better flash routines do a decent job of finding answers in the troublesome areas.
I haven't meant to scare you off from delving further into doing your own DP calcs, but it does help to be aware that there are some areas where simplifying assumptions can give misleading results. HTH
I would seriously question the accuracy of fugacity coefficients that are not derived from a respectable (and field-proven) equation of state. It is one thing to do a simple hand calculation (using gross approximations for K-values) just to "get the hang of it", quite another to develop a stand-alone, reliable procedure that is both generic and computationally efficient. You don't sound keen to program a rigorous procedure yourself. This is wise because doing rigorous hand calculations with a cubic EOS for even one complete iteration would take you a month of Sundays.
Also, remember that cubic equations of state are among the simplest of the options available. There are far more complex (and accurate) EOS alternatives that one cannot even begin to contemplate applying in a hand calculation.
Lest my comments are misconstrued, I - like Milton Beychok - applaud your basic position: complex computer calculations should NOT be used without any understanding of the fundamentals. Unfortunately, this is not a common sentiment these days. Many employers create a work environment that values "productivity" at the expense of even the most basic understanding. Even chemical engineers often do not get an in-depth exposure in under-graduate school to such calculations as we have discussed here.
I am suprised that no explicit mention has been made of the De Priester nomographs, which were the standard hand VLE calculation method taught for Flash, DEWT, DEWP, etc calcs when I was in school (and most likely never used by us again after graduation). Many texts include these nomographs. Easy to understand and as these were developed circa 1950, they may be well worth a check out for an "old timer" who wants to understand the calcs by actually trying them out.
best wishes, sshep
Good point about the DePriester nomographs ... which are still available in the 6th Edition of "Perry's Chemical Engineers' Handbook".
Perhaps the reason they weren't mentioned before is that they simply provide the equilibrium k=y/x values used in the VLE calculation methods ... and this thread has concentrated more on the calculation methods rather than the k values.
Milton Beychok
Once again thank you all for your advice.
I think it is time for a recap of what I am trying to do, which to calculate (and understand the methods of such calculations) the hydro carbon dewpoints of natural gases of differing compositions up to pressures of 70bar.
If it at all possible I do not want to use proprietary programs or get involved complex equations of state or flash calculations.
It is for this reason that I described my proposed calculation method in my post of 29 December 2005 which is based on the method first suggested by TD2K. With my proposed method the only information I am missing is the equilibrium values of k=y/x. If these values can be obtained from fugacity coeffs determined by software by ALLPROPS then this will satisfy I think. If not then I will use available graphs and turn them into look-up tables.
So why do I want to determine HCDP for natural gases. Well for combined cycle power plant, the gas turbine suppliers want the fuel gas delivered to the GT at a temperature that is above the HCDP by some margin. As a consultant, I want to estimate the HCDP at a preliminary concept /feasibility /design stage. It will be for the GT contractor to design and supply the fuel system that will deliver fuel gas to the GT at the required conditions based on the analysis of the gas delivered at the plant boundary.
At this moment I am struggling to understand what is wrong with my proposed method. Although I do recognise the pints made above about the impact of small contents of C6+ components on calculated HCDP and the concept of a measurable dew point.
Best regards,
athomas236
However, if I were paying you as a consultant to provide me with engineering services and you had access to superior information or methods and chose not to use them than I would be a bit disappointed. I don't want to sound harsh but sometimes I come off that way before my morning coffee.
However, in the 1940s, it was impossible to do fugacity coefficient calculations by hand using such a complex EOS, as there were few computers around. Therefore, Kellogg came up with a large collection of charts called “the Kellogg charts”, which graphed the numerical solutions of the BWR EOS for a wide range of cases. This was an attempt to introduce the composition dependence of the K-values in an approximate and graphical way, since the actual solution of the BWR equation was not required at all. However, much trial and error was still required to use these charts, and the results were NOT as accurate as what would be obtained through rigorous solution of BWR.
Later, the so-called “MIT K charts” were developed at MIT, that were based on the Kellogg K charts, but were far less voluminous and therefore simpler to use. However, these too required trial and error, but were a lot less laborious to use than the Kellogg charts, and also not as accurate. They were certainly much less accurate than the original BWR equation of state.
Next, DePriester developed two nomograms, based on the MIT K charts, that eliminated composition dependence altogether in favor of real simplicity. There is one nomogram for “high temperature” (-5 to 200 C) and another for “low temperature” (-70 to 20 C), and there is an area of overlap where the K-values values do not quite agree. These K-values may be used by the brave of heart for pure hydrocarbon systems at moderate T&P only. One must also decide which one to use when there is an overlap. No guidance is available of what to do when, for example, N2, CO2, H2S, and other important non-hydrocarbon components are also present. DePriester’s nomograms have survived to this day in many textbooks and Perry, I think for historical reasons, but certainly not because they are known to be in any way competitive with a modern EOS for accuracy. Often DePriester’s nomograms charts are replicated with absolutely no commentary as to their historical origin and especially their many limitations with respect to accuracy. The fact remains that it is dangerous, if not foolhardy, in most situations simply to assume that K-values are independent of composition. This is why phase equilibrium remains a pervasively important area for chemical engineering research.
Therefore, I would again urge anyone reading this thread to be aware that computational simplicity for K-values generally comes at an intolerable sacrifice in accuracy. There simply is no way to get quick and dirty K-value answers to a given problem, such as a high-pressure natural gas dew point calculation, that is also likely to be accurate except by pure chance. That is why everyone uses a standard process simulator for such work.
Note for the most intrepid ChEs out there: if a dew point calculation is bad enough to do by hand, imagine how laborious a fully rigorous multicomponent distillation column calculation would be, using any of the most common convergence methods, since many thousands of composition-dependent K-value sets would be required before column convergence is achieved. (Dick Russell will excuse my not elaborating on his “inside-out” method which greatly reduces the number of K-value computations required in distillation).
-Robert S. McNamara
I would like to add to the history recounted in your last posting. In the post World War II era of the late 1940's and well into the 1950's, there was a veritable explosion of construction in the petroleum refining industry ... grass root refineries, refinery expansions, addition of processes developed during the war and shortly thereafter such as naphtha hydrotreaters/cat reformers/FCC units/alkylation units/etc.
All of the major refinery engineering and construction companies in the U.S. (Kellogg, Braun, Lummus, Fluor, Foster Wheeler, etc.) used the Kellogg charts and the DePriester nomograms or similar data to design literally many hundreds of distillation units in refineries and natural gas processing plants.
With perhaps a few exceptions, all of those distillation units performed as expected. To call that "pure chance" is stretching it a bit, don't you think? I agree with you that good simulators are probably much more accurate ... but we can't deny how well those Kellogg charts and DePriester nomograms served us.
I would also point out (as I have done before) that, during the 1940's and well into the 1950's, the only calculation tools we had were slide rules and some rudimentary electrical adding machines.
Milton Beychok
I wish to add that the concept of an EOS for mixtures is not nearly as intuitive to most people as the activity coefficient approaches, although EOS is generally prefferred where applicable (Note an EOS cannot model highly non-ideal behavior). The trick of using various EOS for multicomponent mixtures, from PR and RKS (cubic EOS type) to BWR (from viral expansion) to numeric tables (i.e. steam tables are an EOS for which analytical expression is too complicated to be useful), is choosing the mixing rules. In Aspen-plus for example there is a basic Redlich-Kwong-Soave equation, but a host of different mixing rules that can go with it which are needed to calculate the required alpha functions for mixtures. The BWR parameters as given in the extensive property databank of "The Properties of Gases & Liquids" by Reid, etal are not in themselves useful for mixtures, and it is the mixing rules like Lee-Starling which add this functionality to the BWR equation.
This is all logically developed in theory in a common text known as "Introduction to Chemical Engineering Thermodynamics" by Smith and Van Ness (3rd edition for those of us graduating in the 80's) by following through chapters 3 (volume relationships), 6 (thermo-props of single components), 7 (thermo-props of mixture), 8 (phase equilibria). It is my opinion that "The Properties of Gases and Liquids" is a good text for how to generate a complete set of property parameters from basic data (like structure, boiling point, etc); but that "Intro to Chem Engr.ing Thermo" is the better text for understanding the underlying theory of thermodynamics (like departure functions, Gibbs free energy, etc)- at least that has been my experience.
best wishes as always,
sshep
P.S. After studying the BWR equation, I often thought of developing my own highly accurate EOS- the SShep Equation. I know that it will be very accurate because I will give it at least 100 adjustable parameters. Unfortunately I won't give users these parameters (my own sadistic chemical engineering 'joke'). I will leave to the users to empirically determine those parameters from accurate experimental data (100 parameters = at least 100 data points). At least this is how some of the more "accurate" recently published EOS characterizations have seemed to me.
In general, I agree with the substance of your comments. Regarding the design methods of the past (a favorite subject of mine, since I did much process design in the 1960s), there is no question that those simpler methods and "shortcut" calculations were the only options with slide rules. When I first used the HP-35 electronic calculator in the early 1970s (studying with Professor Manning at Tulsa), I thought I had died and gone to heaven.
In the 1040s and 1950s, I believe that for most columns in petroleum refineries, there were many shortcut methods in vogue. Hardly anyone had heard of using the more rigorous tray-by-tray algorithms based on pseudocomponents in spite of the publication, e.g., of the Lewis-Matheson and Thiele-Geddes algorithms. For light hydrocarbon columns, many designs were based on the Fenske-Underwood-Gilliland shortcut method along with Drickamer & Bradford or O’Connell’s overall column efficiency correlations. Here, one needed K-values at the top, feed, and bottom of the column only. This situation began to change in the 1960s as the universities led the way by devising better algorithms and adding superior thermodynamic options (Chao-Seader, etc.). You might recall Rudy Motard’s CHESS and Canfield’s ChemShare programs.
However, in the 1960s and even mid-1970s, I do recall that individual engineers never had the wherewithal to do tray-by-tray calculations as they lacked access to computers. Major operating and engineering companies used highly proprietary, home-grown process simulators running on very slow computers by modern standards, often with approximate thermodynamics (e.g., tabular K-values dependent only on T and P). The trick of course was developing standardized calculation methods backed up with consistent “tray efficiencies”, heat transfer coefficients, etc. that were based on field calibration.
My main point was not to decry the efforts of the past but rather to reinforce Dick Russell’s original contention that hydrocarbon dew point calculations are extremely sensitive to the feed composition as well as the source for K-values.
With respect to sshep’s discussion of EOS v/s activity coefficients, I would like to add that the latter method is generally applied when the liquid phase is extremely non-ideal in the sense of Raoult’s law (infinite-dilution activity coefficients very far from unity) and all components are well within their critical temperature. For the hydrocarbon industries where many components in a mixture are way beyond their critical temperature - and hence cannot be handled by any method that estimates liquid fugacities based on vapor pressures - the fugacity coefficient approach derived from an EOS is the only logical option. Use of tabular or graphical methods in such systems is not recommended practice today by any means, as there are many instances where one could court disaster by doing this. Unfortunately, too many younger engineers have no idea of what we’re talking about here.
Also, I do agree with sshep’s point about the importance of EOS mixing rules (and the implied use of adjustable binary interaction parameters). This is in itself a huge area for research, see e.g., Prausnitz, Lichtenthaler, and Gomes de Azevedo: “Molecular Thermodynamics of Fluid Phase Equilibria” (3rd edition, Prentice-Hall, 1999) and Orbey and Sandler: “Modeling Vapor-Liquid Equilibria” (Cambridge Univ. Press, 1998). One must be extremely careful to choose the right mixing rule since published binary interaction parameters are worthless if you change even slightly the mixing rules on which they are based.
In retrospect, we may have strayed a bit from the original dew point issue, but it seems a logical departure to me at least. I would commend all who have contributed to this thread, as I think there is much knowledge and experience “distilled” here.
I spent a couple of hours Friday night reading chapters 15 to 25 of Volume 1 of Edmister's book "Applied Hydrocarbon Thermodynamics" which was rather a lot to absorb in one sitting.
It seems to me that if we had an extensive data base of K factors then we could just interpolate to get the required values of K. (I have omitted reference to mixing rules only because I have not yet read anything about them.)
However, since we do not have this all encompassing data base, we are left with the necessity to generalise the available data so it can be used in circumstances not covered by the available test data.
Clearly there are simple methods that could be used to make such generalisations and more complex methods with the simple methods being easier to understand but carrying a higher risk of not being applicable in all cases and therefore less accurate. It is possible that the greater accuracy of the more complex methods is an illusion.
If we say for discussion purposes, that the test data that under pins all generalisations has an error of +/-5% and that the simple methods have an error of +/-5% while the complex methods have an error of +/-1% then very simply, the simple methods have a combined error of +/-10% and the complex methods +/-6%. The point being that no matter what calculations methods are used, the results cannot be more accurate than the original test data.
As stated by mbeychok we know the simple methods worked but the problem was the time taken to make manual calculations. This problem was solved by computers but computers gave the opportunity to use more complex methods of calculations.
So we have moved from simple calculation methods that were easier to understand, time consuming to make but suitable for say 90% of the circumstances in which they were used through simple methods using computers that were not time consuming but again easy to understand and suitable for 90% of circumstances to complex methods that are not time consuming to use suitable for say 95% of circumstances but are not always easy to understand by the people using them. In part this is due to the fact the calculations are locked inside proprietary compute code.
What I want to do, as a consultant, is to calculate HCDP using simple methods that I understand and are applicable in 90% of cases using a computer. This will leave the contractor to make his own calculations in the event that any project that I study gets constructed.
I know that all the above is a gross simplification but I think it represents what I am trying to achieve, whether it is achieveable or not remains to be seen.
Best regards,
athomas236
Now we are in the area of opinions, so please bear with me for stating mine forthrightly: If you are a professional engineer and consultant, it behooves you to use the best methods available. If you don't understand them (i.e., they are outside your area of expertise), hire a professional chemical engineer to check/certify them if there is a possibility that ANY third party may rely on your computations in any way. I wouldn't advise use of any computations merely because, right or wrong, they are easy to understand.
Also, there are reliable flash calculation programs available for a nominal cost (<$500) that use the proper thermodynamics. This should be an expense that is insignificant compared to the value of most consulting assignments. Of course, even using the EOS approach requires some level of maturity to avoid improper EOS choices or inadvertent use of the wrong mixing rules. However, most gas contracts specify, in some detail, the options that must be used.
My quite recent experience with HCDP calculations is that use of less reliable thermo options can lead to errors of 10 deg F or more which, in my opinion, is utterly unacceptable for design work. Usually, gas plants go to great lengths to ensure that the HCDP they achieve is well within the specification (because of some uncertainty in gas composition measurement) as the penalties for sustained violations can be intolerable.
To follow your example, a 5% error in the composition of the heaviest ends can easily distort the calculated HCDP by 30 deg F or more. Therefore, for contractual enforcement, automated daily composite samples are usually taken and then are subjected to very accurate off-line gas chromatographic composition analysis, especially focusing on the breakdown of the tail end (C6+ fraction). I have seen instances where both the supplier and the receiver have their own sampling and analysis stations to avoid errors and ensure proper data reconciliation.
My main concern is: In these litigious times, can one afford not to use the best available methods? Believe me, the fines for violations can be intimidating even for major operating companies as we are dealing with a serious safety issue here: if heavy components separate out as line pressure is decreased (retrograde condensation, a common phenomenon in gas pipelines), a gas user could be faced with a major slug of liquid entering his gas burners. Depending on the distribution piping network, these slugs can accumulate undetected over a period of time and then suddenly disgorge themselves. If the boiler or furnace doesn’t have a disengagement vessel at the gas inlet, imagine the horrible consequences.
So, I am quite paranoid about such matters: being torn apart by an expert witness in a legal proceeding would be my notion of chemical engineering hell.
Again, I commend you for initiating a very pertinent discussion.
