Trane TRACE 700
Trane TRACE 700
Trane TRACE 700
Does anybody know of an active forum for TRACE 700 users?  I am looking for a users group that can help me move from beginner to more advanced user.
Thanks in advance.
RE: Trane TRACE 700
I don't know of a forum dedicated to Trace 700, but this forum should suffice if there are enough users here.  I have been using Trace 700 for almost 2 years now; I'd be happy to help however I can.
RE: Trane TRACE 700
Okay, here's one.  The client has asked for a copy of the source data.  Do you know of any way to display/print a summary of the Room & System information as input?  I can't find anything in the Help menu.
The only way I know to do this is an ALT-PRINTSCREEN to capture the active window and save each Room tab and System screen as a separate .jpg file.
If you can suggest a better way, please let me know.
Brad
RE: Trane TRACE 700
     At the project navigator screen, hit the view menu and click on entered values. Put a check mark on room and system information boxes. I advise you to put a check on the print preview box so you will not waste any paper. Page thru the input values of the rooms and systems you want to print. Also, there is an option to save this information to disk if you like.
RE: Trane TRACE 700
Thanks, that's exactly what I needed.
