Burst my Balloons
Burst my Balloons
Dear Folks;
I have a SW 2006 SP2.1 assembly drawing showing an industrial fan with electric motor, an inlet box and associated ductwork. The fan and motor are a single assembly so that when you balloon them, they show up as a single item. Everything else in the assembly shows up as a seperate item as required.
I would like to show the fan and motor as seperate ballooned items without taking the motor out of its assembly. (The motor is part of a top-down assembly which drives the fan belt guard and sheaves depending on nema frame size and fan size.)
Is their any simple way to do this without losing associativity and maintaining bill of material relationhip. I know I can use custom numbers in the balloons but then the relationship to the bill will be broken.
Merry Christmas to all !, and many thanks
Adrian Dunevein
www.aaadrafting.com
Adrian Dunevein
www.aaadrafting.com
RE: Burst my Balloons
I guess you could make a main assembly Config & Suppress all the un-needed components and BOM it that away and use Indeneted Assemblies -Show numbering then Balloon it.
You can do this within the same drawing sheet if you need to.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
"I think there is a world market for maybe five computers."
Thomas Watson, chairman of IBM, 1943.
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
Windows 2000 Professional / Microsoft Intellimouse Explorer
SolidWorks 2006 SP02.0 / SpaceBall 4000 FLX
Diet Coke with Lime / Dark Chocolate
Lava Lamp
Thanks for your help. Parts only is the simple solution I was looking for.
Best Regards
Adrian
