Stainless Steel question
I need to know what 1Cr18Ni9 is.  Is it 304 Stainless Steel?  Also, what is 40Cr, and QT500-7?  I think the QT500-7 is some kind of Bronze or something.  Any help would be great.
Thanks.
RE: Stainless Steel question
1Cr18Ni9 is China Standard GB1220 equivalent tp 302 Stainless Steel. A cross-listing of Chinese & international equivalent SS's is at
http://nhyh.com/en/productsteelhao.asp
40Cr is a Chinese high strength steel used in oil well drill pipe. Looks like "40" is 0.40 wt% C, "Cr" ~ 1 wt% Cr.
40Cr composition:
0.40 C, 0.95 Cr, 0.65 Mn, 0.18 Ni, 0.27 Si, 0.01 P, 0.01 S (Fe balance).
QT500-7 seems to be a Chinese performance standard for nodular cast iron:
"Continuous Cast SG Ductile Iron Bar
QT500-7
ASTM A536-84 65-45-12 / 80-55-06 / 100-70-02
JIS FC D45
DIN 1693 GGG40
BS 2789 SNG 27/12"
from http://www.dhcasting.com/continuous_cast_iron_bar.asp
