form wound vs. random wound
Anyone know the differenc bewteen these two types of windings for low voltage generators?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: form wound vs. random wound
Form wound means the coils are wound so as to minimize the voltage stress on the winding insulation. Some people feel this provides an advantage in the ability of the insulation to withstand high voltage transients (i.e. waveform notching caused by rectifier loads). The alternative (less expensive) is what is called random wound.
Personally, I have clients who have literally hundreds of random-wound gensets feeding various rectifier and electronic loads, and I know of only one winding failure in ten years.
http://www.kato-eng.com/fwrw.pdf#search='kato%20form%20wound'
I normally won't do this, but this was easy. I would expect you do your own search and try to find answers yourself, may be post here as info.
Form Wound Coil is a coil made with SQUARE or RECTANGULAR wire.
Random Coils is a coil made with ROUND wire.
The main difference with this two winding types is the wire type.
In form windings you most insulate all coil wrapping mica and glass tape arround all coils and for large machines you could change a part of the winding in some failure cases, in random windings you insulate the slots and place insulation between each end coil.
I would prefer the form wound coils due to this winding will last more time in operation and for design point you can use high volt/turn ratio, also the mechanicall stress due to magnetical forces is avoided due to the coils will fit OK on the slot.
petronila
