AIR FLOTATION SYSTEMS
Hi there!
I' doing a survey on air flotations systems in order to optimize ours, which has started-up three weeks ago, (dealing with mixed used-oils/water. It has been working at 92 % of stated project data. I intend to explore all the system possibilities, and the control procedure as well. Is anyone has specialized information, related references, sites? Thank You!
Merry Christmas to you ALL!
WTA.
RE: AIR FLOTATION SYSTEMS
Welchita:
Tell us what you are using in the way of demulsifiers, flocculants and coagulants, if any. One or more of these may measurably improve system performance which I assume you are measuring as oil/water separation efficiency.
If these are not in use, I'd suggest having one or more vendors such as GE Betz, Nalco, Baker-Hughes, etc. do the bottle testing of their products for you to pick and choose from.
Orenda
