converting visio fills into autocad files
I am using Visio ver 5.0a Technical.
The project requires that drawings be done in Visio, saved as Autocad dwg files, and later converted using Whip-N-Post to dwf files for web pages. (the dwf feature of Visio does not work)
The problem is that when I use Visio fills the fill portion does not translate into the Autocad dwg file when I use
RE: converting visio fills into autocad files
I do - I save the *.vsd file in *.pdf format, than using Adobe Acrobat I save it like *.htm or *.xml.
TTFN
