Welding progression uphill / downhill in Sec IX
The question is whether it's enough to qualify a PQR for both uphill and downhill when a welder makes one continous bead all around the pipe in 6G without stopping? May seem strange, but I found no clarification about it.
Konrad
Konrad
RE: Welding progression uphill / downhill in Sec IX
Say, the sample is 25mm OD tube and the welder makes three GTAW welds in G6, all round without stopping. I can make 4 samples for bending out of first of three welds. This will give one sample from top, one from bottom, one uphill and one downhill. The second and third weld will go to full section tensile testing. Is this enough to have both uphill and downhill qualified?
Konrad
Since you are needing a WPQ, you must test for both uphill and downhill progression. In your case, you may be covered, just be sure you have the proper number of bend coupons representing each progression.
This is exactly my concern: QW-356 lists "progression" as a variable. But QW-302.3, QW-452.1(a), nor QW-463.2(d) does not say that the opposite specimens have to be the same progression. Is there some requirement saying so?
Konrad
Let me explain my problem more percisely. Is there somewhere in Sec. IX written:
one uphill qualification=4 uphill specimens,
one dowhill qualification=4 downhill specimens,
one uphill+downhill qualification=4uh+4dh specimens?
Isn't it enough to have 2 uphill and 2 downhill specimens from one weld acc. to QW-463.2(d) ?
Konrad
Since progression is an essential variable for welder qualification, a test assembly is required to represent each of those conditions. If it were plate and two coupons were required, you would need two coupons with uphill progression and two with downhill progression. When testing a welder on pipe, if four coupons are required, you would need four for each progression.
I'm not aware of a paragraph which spells this requirement out, but, the key is QW351 'a welder shall be requalified whenever a change is made in one or more essential variables'
Plate for PQR and pipe for WPQ, regardless of savings,
I am small too and have many procedures.
when you want to save too much, it is no good. I have lots of experiency on that.
I used top save a lot, at the end it is not worth the effort.
genb
Konrad
