Flat spring design
Flat spring design
Please can anyone help urgently.
I need to design a flat spring that will keep a circular object in place on a metal casting. It needs to be in the form of a three arm spring with each arm providing constant force, however I can not find any formula etc that will help me design it - Help please
Cheers
Parsnip
Cheers
Parsnip
RE: Flat spring design
http://www.webspawner.com/users/israelkk/
The book Spring Design by Berry as a good section on calculating flat and shaped springs in rectangular spring material.
If you give us more detail in what you are trying to do we may be able to help you further (ie;-physical size of circular object, mass, material and position of supporting springs:-horizontal or vertical, finally any enviromental conditions.
regards desertfox
