17-4 Stainless in Tube Form
I am currently working on a application that requries 17-4 stainless in tube form. I have had NO luck in sourcing it out. We have to resort to gun-drilling round bars, which is an absolute waste. I need help finding this 17-4 in tube form. I hope somebody can come to my rescue.
Marin
RE: 17-4 Stainless in Tube Form
Ed will be here soon to rescue you.
Thanks for the vote arunmrao!
There used to be seamless 17-4 available from both Japan and Northern Europe.  Limited sizes, expensive, and very long lead times.
How about using 17-7 or Custom 465 as an alternate?  These alloys can be welded and then cold drawn to size.  We have seen a number of applications convert in the last few years because of sourcing difficulties.
Give me an idea of the sizes that you are looking for.
ed
Corrosion, every where, all the time.
Manage it or it will manage you.
http://www.trent-tube.com/contact/Tech_Assist.cfm
Plymouth Tube manufactures 17-4 tube.
http://www.plymouthtube.com
Cory
First of all, thank all of you who responded to my request.
17-7 will also be ok, or I need another stainless comparable to 17-4 that would not melt when tempered and brazed to cpm 10V (A11). This application requires a substrate of stainless compatible with the tempering temperatures of 10V:
Hardening 10V
Preheat:  Heat to 1500-1550 F (815-845 C) Equalize
Second pre-heat stage at 1850-1900 F (1010-1040 C) suggested for vacuum or atmosphere hardening.
Austeniztize: Heat to 1850-2150 F (1010-1175 C), hold time at temperature 30-45 minutes.
Quench: Air or positive pressure quench (2 bar minimum) to below 125 F (50 C), or salt or interrupted oil quench to about 1000 F (540 C), then air cool to below 125 F (50 C).  Salt bath treatment, if practical, will ensure the maximum attainable toughness for a given hardening treatment.  Vacuum or atmosphere quench rate through 1850-1300 F (1010-705 C) range is critical to achieve optimum heat treat response.
Temper: Double temper at 1000 F (540 C) minimum, 2 hours minimum each time.
Size Change: 0.03 / 0.05%
I DON'T KNOW OF ANY OTHER STAINLESS THAT WOULD SUSTAIN THESE TEMPERATURES WITHOUT MELTING AWAY? ANY RECCOMENDATIONS?
