High temp valve
High temp valve
High temp valve
Dear Gentlemen,
I´m looking for a 725psi, 700degC valve and pressure regulator for a Autoclave piping.
I´m not normally a pressure vessel designer.
Does this kind of components exist or do I need to use a heat exchanger first to lower the temperature?
RE: High temp valve
What is the media. is it steam?
