Raising to a power on both sides of an equation
Howdie.
I am new to MathCAD, and can't seem to find a solution to a basic problem, which is this:
If I have the equation t = u + r, is there a way to square both sides automatically to get t^2 = u^2 + 2ur + r^2?
The reason I'm asking is that I have a HUGE expression that is probably going to result in a quartic, and squaring the equation will take forever and probably result in hard to find errors across 3 or 4 pages.
Thanks in advance,
treddie
RE: Raising to a power on both sides of an equation
Since your new then just follow the basics. Everything must be defined unless your working symbolically, otherwise it turns red. The left side of your := and the right side are not one in the same. Reassign a variable to represent t^2 and then use that variable in your next expression.
below, a b c and d would all have to be defined.
When you get better at the software you can create arrays or sequences and even do programming. but for now lean the basics.
a=1 b=1 c=2 d=2
u:a+b
r:= c+d
t:= u + r
t=6
x:= t^2
x=36
You can create subs to explain but you can't say t^2 :=
Not sure what you are trying to do.  You can square the RHS by using the symbolic processor
TTFN
