Tables & Model Properties
Hi everyone. So I've done a search for this, as well as looked in the help files.. and I'm sure the answer is just right under my nose but I can't seem to get it.
Here is what I have done.
1. Made an Assembly of a sandwich panel.
2. Located the position of where I want to put the inserts and used the Assembly Feature>Hole Wizzard to create each hole.
3. In the model I have named the features and the feature desc. by what P/N I will use to pot in the holes.
What I want to do.
In the drawing, I create a Hole Table, which gives me 4 cols. Col, 1, 2 & 3 Define the feature. Col 4 right now gives the Hole Size (as defiined by the hole wizzard tool. I want to replace this with the Assembly Feature "NAME", so I don't have to go and manually over write the hole size...
When I can figure this out, I will save the table off, so I can use it on other assys'
Wes C.
When they broke open molecules, they found they were only stuffed with atoms. But when they broke open atoms, they found them stuffed with explosions...
