tangential placement of a curve on curve
I have to place a fillet (curved end of an object), say curve A tangent to another curve, say curve B. One constraint I have is the location of curve A is fixed from the horizontal plane. Curve B is fixed in all respects (x,y,z). So if I want to place curve A tangential to B at a particular value above the horizontal plane, how can I ensure tangency between the two curves.
Here is what I did. I fixed the vertical distance of curve B, turned on my ortho and moved the curve B horizontally very slowly and kept regenerating. When I was reasonably close I made sure I snapped to the horizontal and tangent.
What I have right now looks right, but am not sure if I am convincing myself the right way.
How do I go about this?
RE: tangential placement of a curve on curve
Can you use the TAN OSnap?
Are you saying that you want both
curves to have their maximum point
on the horizontal line?  If so
you can draw a strait line strait
up from the center of each curve
at a length equal to its radius of
curvature.
Then move the intersections of the
strait line and each curve to the
horizontal position.
So what you are saying is that curve A can have its center anywhere on an X axis parallel to your horizontal plane. Knowing the radii of both curves, sum them up and draw an arc having a radius of that summation and whose center is the center of curve B. Let that arc intersect the X axis of curve A and that intersection will be curve A center from which you can draw curve A and which will be tangent to curve B.
