Measuring Combustion Efficiency Using Flue Gas?
Burning Bunker Fuel Oil:
Using chromatographic testing of flue gases, can a measured reduction in contaminating emission products in kg/h be translated to a measured reduction in the fuel oil being burned, kg/h?
i.e.
Change in Unburned Hydrocarbons in kg/h = 'x'barrils fuel oil
i.e.
RE: Measuring Combustion Efficiency Using Flue Gas?
"...students of traffic are beginning to realize the false economy of mechanically controlled traffic, and hand work by trained officers will again prevail."
Wm. Phelps Eno, ca. 1928
I think that you take temperature and co and co2 ratios into account to measure combustion efficiency.
I know that there are meters that you simply stick a probe into the flue gas stream and read efficiency.
However better to try the mechanical forums for the correct answer.
Rick Kitson MBA P.Eng
Construction Project Management
From conception to completion
www.kitsonengineering.com
