Electro Slag Strip Cladding versus SAStrip Cladding
Hello All
All other variables remaining same which is superior process (ESSC) or SASC? From the point of view of SS Overlay/Inconel 625 Overlay.
Which has high heat input and What is the expected Basemental chemistry proportion in the first layer of Welding (Dilution properties)?
ASME Sec II C does not deal with SS/NF ESSC Flux. Is there any other Standard that specifies the guideline for SASC or ESSC.
RE: Electro Slag Strip Cladding versus SAStrip Cladding
http:
It is questionable if the elements you submit are sufficient to identify a "superior" process. If dilution is a problem it is usually controlled using a buttering layer. Current is the parameter having the highest influence on dilution.
http://www.welding-advisers.com/
http:
