Autocad layers
Autocad layers
Autocad layers
i wanna make changes to the drawing after i transfer the layers onto the other file.How can i do it as after i transfer the layer it automatically becomes a block and i need to explode the block so that i can make changes to the drawing after transferiing it to the other file.how can i do it?
RE: Autocad layers
You should probably be posting in the CADD forum.  Are you talking about x-refing a drawing or block writing?  I can't quite figure out what you are trying to do.
RE: Autocad layers
no need to block and insert, just use copy and paste (ctrl c and ctrl v) to copy the entities and then paste them into another drawing.
