ASME Section VIII Nonmandatory Appendix
Are the items in a "nonmandatory" apendix truly nonmandatory, that is do not have to be met. For example, in Appendix M relief device inlet and outlet allowable pressure drop are specified. Are these requirements that have to be met, or only suggestions?
RE: ASME Section VIII Nonmandatory Appendix
So since this non-mandatory appendix is specified in the Code, do the requirements in this appendix now become mandatory?
The Code committees cannot write rules for every application. Therefore, Nonmandatory Appendices are intended to provide general guidance.
