Converting Microstation cells to AutoCAD blocks?
Has anyone found a way to bring cells into AutoCAD, without having a copy of Microstation? Autocad can import .dgn files, but apparently not .cel files.
Any advice would be appreciated.
     "...students of traffic are beginning to realize the false economy of mechanically controlled traffic, and hand work by trained officers will again prevail."
              Wm. Phelps Eno, ca. 1928
RE: Converting Microstation cells to AutoCAD blocks?
What version of AutoCAd can import DGN?
Are there a lot of cells you need imported?
I downloaded Bently Powerdraft (was free for students).  It is a slightly scaled down version of microstation, but works with cells.
check here first  http://www.be.org/en-US/BE+Careers/Free+Download.htm
http://www.bentley.com/en-US/Products/Bentley+PowerDraft/Overview.htm?market=Building
Hope this helps.
I enjoyed using microstation.  I found it had several nice features that AutoCAD could use.
