Double arrows on detail view dim's
Is there a way to have diameter dimensions on a detail view show with double arrow heads?  Also, my dimension lines entend to where the other attachment point would be.  I would like to relimit those dimensions lines.
RE: Double arrows on detail view dim's
I found where I can change the arrow head style, but i would still like to relimit the dimension line so that it is not so long.  If I am going to show the entire dimension line, I might as well show the entire view?
