SA-414 Tension test Specimens from coil
SA-414 1.3 : "- tension test specimens are taken to represent the middle of the slab -".
If we only cut 25% of the coil is it then permitted
to take 2 test specimens, one in the start and on at the end.?
RE: SA-414 Tension test Specimens from coil
LOOK AT THE ASTM STDS
GENB
