Should I be using PDM works and server?
I am the only one for my small 3 person company designing in Solidworks, should I even bother setting up PDM works? what benefits would it give me?
RE: Should I be using PDM works and server?
The advantages that it would buy a single user operation would be to enforce unique file names and provide a structuring for storing library and project files.
"Fixed in the next release" should replace "Product First" as the PTC slogan.
Ben Loosli
Sr IS Technologist
L-3 Communications
Chris
Systems Analyst
SolidWorks/PDMWorks 05
AutoCAD 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
1. Get the revision scheme down.
2. Decide if you want lifecycles (Inwork, Release, Obsolete).
3. Decide on a standard file naming convention, usually some part number. You won't be able to check in two files called "Plate".
4. Go through the tutorials and checkout the subscription area for best practises.
5. Decide on a "Project" structure. This could be by "Job" or by "Product". You can also have sub-projects.
6. Consider additional custom properties you might want to track on each file.
I would go through this before you just jump in so that most of the data in there is consistent. Install the vault and play around with the options. You can always reset the vault later and start over.
Jason
UG NX2.02.2 on Win2000 SP3
SolidWorks 2005 SP5.0 on WinXP SP2
SolidWorks 2006 SP1.0 on WinXP SP2
Pros:
1) Easier to find docs - better search than windows
2) REV tracking
3) Easier to reuse common files
4) Share documents - with AS license you can even set up a webportal to give non-designers access to your drawings
5) Seamless expansion of the design department - document sharing is already taken care of
Another thing to ask yourself is do you expect to see some growth in your company to the point where you might at some point in the future be working with someone else. Getting set up with PDMWorks now will allow the transition to be easier later, as a system will already be in place and you'll already have experience with it before you have to explain it and possibly teach it to someone else.
Yes, almost everything has been said.
One of my reasons would be, because of the as built feature. If 3 years from now a customer wants an exact copy of a $5214 machine which has 43 parts, I can pull up his revision and ask for as built. All the drawings exactly as the customer has are ready to print.
Make is simple. Setup 2 users, yourself and Vault admin. Revision Scheme setup primary and secondary. Projects setup 4 to start, Prod Released, Projects, hardware and obsolete. Set your permissions and you’re done.
There is more, but at a later time.
Bradley
But is there a way to set up the pdm server to be hosted on a server out on the internet? I don't want to host another server running on my local desktop at home..
Bradley
Bradley
