Harmonic analysis of a differential milling cutter
Hi fellow engineers,
As a part of my work i need work on the harmonic analysis of the milling cutter with differential pitch. Can anybody give me the idea how can I apply the load on a differential pitch cutter(for ex. a cutter with 5 inserts), so that i can run the simulation. And my task is to minimize the catter. So please give me your valuable ideas about modelling and load application also.
Thanks in advance,
Krishi
Thanks in advance,
Krishi
