Triangle-headed Lag Bolt
I'm looking for information on a 1/4-20 bolt that looks very similar to a lag bolt, except the head is triangle shaped rather than square. Any information on a fastener name and supplier would be great.
"I think there is a world market for maybe five computers."
Thomas Watson, chairman of IBM, 1943.
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
RE: Triangle-headed Lag Bolt
If you only need a few, then buy the hex head lag bolts and have the heads machined into triangles or anything that makes you happy.
StoneCold
It's suppose to be a common feature, but I guess "common" is a relative term.
http://www.alcafasteners.co.uk
http://mdmetric.com
BTW, this is from a simple google search for "triangle head bolt". Next you'll probably ask about the mating wrenches. DIN #22419.
http://www.metricmcc.com/catalog/Ch4/4-412.pdf
