creating PDF's in Pro/E
I want to save PDF's from Pro/E Wildfire2. Also is there a way to convert HPGL2 or Postscripts to PDF'S directly? We have traditionally saved polt files for rev history and I would like to create PFD's from them.
KTG
KTG
RE: creating PDF's in Pro/E
You can also use adobe distiller to convert Postscripts to PDF files. But 995 is free
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
o
_`\(,_
(_)/ (_)
"Coming together is a beginning, staying together is progress, and working together is success." - Henry Ford
In WF2, you can set the config.pro option adobe_distiller to the location of your Adobe Distiller executable (mine is C:\Program Files\Adobe\Acrobat 6.0\Distillr\acrodist.exe), and you will be able to create PDFs directly.
Once you've done this, go into Tools-->Customize Screen and add the 'Save as PDF' button to an appropriate location in your toolbars.
Dave Hyman
iRobot Corp
www.irobot.com
Hope it helps.
The link:
http://www
