NEED HELP FOR SCHEMATIC DESIGN OF A SYSTEM GENERATING DSBSC AND SSB
   I need schematic design( using active and passive elements) of a system taking an information signal and a carrier wave as input and generating a DSBSC and SSB with both bands.
thanks
Amazon
RE: NEED HELP FOR SCHEMATIC DESIGN OF A SYSTEM GENERATING DSBSC AND SSB
SSB with both side-bands ?
What is your freqency range and carrier ?
How much residual carrier is allowed ?
Any other specs?
<nbucska@pcperipherals.com>
   The frequency range allowed is 300 hz to 4000hz and the carrier frequency is 100khz and the carrier amplitude (Ac) is 50.The information signal m(t) is to be modulated with the M(f) which is the fourier transform of the information signal. And Max[M(f)] is 10.I need to design the system which generates s(t), which is DSBSC, Su(t)Single side band(upper), Sl(t)which is Single side band(lower).Any active or passive elements can be used.
  thanks for trying to help.
Amazon.
The project doesn't look too difficult.
Search e.g. <www.digpile.com>; for "single sideband", you will find more than enough info.
