SCC of 17-4PH H900 Drive Rod
I am currently working on a 17-4PH H900 drive rod that failed by SCC.  I am having troubles nailing down the possiable causes of SCC in 17-4PH.  We have found traces of cholrine and sulfur in the corrosion products.  The rod would have operated at temperatures up to 300-F.  Are cholrin or sulfur known to cause SCC at these temperatures?  Also, pits were observed along the surface that the SCC intiated.
Thanks for any help anyone can offer.
RE: SCC of 17-4PH H900 Drive Rod
YES.
If you have pits then you have active corrosion.  Once that happens CSCC will be a high prob.
One problem with PH grades in there highest strength condition is that the CSCC easily.
Corrosion, every where, all the time.
Manage it or it will manage you.
http://www.trent-tube.com/contact/Tech_Assist.cfm
Thank-you all for the resources.  They were very helpfull in this situation.
While MSFC-SPEC-522 remains a valuable reference, it has been superseded by NASA-STD-3029 http://psrp-pub.jsc.nasa.gov/docs/3029.pdf (which isn't much changed from MSFC-SPEC-522)...
The docuement located at the NASA link I supplied above is already out of date.  MSFC-STD-3029 (not "MSFC-SPEC-3029" as I typed above), is currently at the "A" revision...
