PDM/Works VAULT ERROR 102
Hi all,
We've recently installed PDM/Works 2006 and I am responsbible for getting it up and running. In trying to check-in a drawing and related part, I get the following error:
VAULT ERROR 102:
You have no permissions to change document properties
Failed on check in of (drawing name)
Check In aborted
I have "Allow change document properties" turned on the global settings
Thanks in advance
VAULT ERROR 102:
Check In aborted
Thanks in advance
RE: PDM/Works VAULT ERROR 102
Are you the PDM Admin?
Bradley
Chris
Systems Analyst
SolidWorks/PDMWorks 05
AutoCAD 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
I am the PDMworks Admin. I know that they do have the proper rights to the project. Plus they are doing a new check-in, so having ownership at this point is not possible. The user is picking the correct project to check-in to.
PLEASE Help....
I am in a similar situation to Jakek - I am also the PDM Admin and this is a new check-in.
We are using the following service packs:
CLient Version: PDMWorks 2006 SP2.0 Build 0052
Vault Version: PDMWorks 2006 SP2.0 Build 0052
Thanks again
I am also waiting for a response from my SolidWorks reseller so if I hear anything I will let you know.
I logged in as VaultAdmin and checked under the Lifecycle Tab. Under the "Control access to document revisions at the selected status as follows" seciton, you have to provide RW access to users. You may not want to give access to all lifecycle stages, I've limited Configuration Control to Administrators.
Thanx.
Thanks for the valuable info. A star for you both.
