Change elments
Change elments
Change elments
Hi.
I'm making up a model. I have defined two elements:first plane42 and then beam3.
I have meshed all the areas with plane42, now I want to use beam3 in order to mesh a line.How can I say to the program that now I want to change element to use
RE: Change elments
you use the type command. For example:
CODE
type,2 ! if et,2,beam3
mat,...
real,...
lmesh,...
