Sulphide stress cracking
Can sulphide stress be caused in 304 stainless steel in presence of H2S and chlorides if it is under compressive load?
RE: Sulphide stress cracking
Even when the nominal loading is compressive there will be tensile stresses some where. If you load a part heavily in compression and then release the load the residual stesses will be dominantly tensile.
Corrosion, every where, all the time.
Manage it or it will manage you.
http://www.trent-tube.com/contact/Tech_Assist.cfm
