re-use exploded view
I am now doing some consulting work and it has been about 3 months since I have used SW 2006 and it seems that I have lost my touch so if you guys and gals can help me that would be great.  I am trying to create an exploded view of a part which follows in line with another "exploded sub assy" so when I right click on the part that I want explode I notice that there is an option to "re-use sub assy explod" how would I go about using this since I get an error message saying that "none of the selected sub-assy has an eploded view to use" but the sub assy that I want to use is exploded in both the Z and x direction?? what am I doing wrong.
RE: re-use exploded view
Does the sub-assy have configurations? If so, the config you are using must have an exploded view.
Jason
UG NX2.02.2 on Win2000 SP3
SolidWorks 2005 SP5.0 on WinXP SP2
SolidWorks 2006 SP1.0 on WinXP SP2
Click the sub-assembly first (make sure the select sub-assembly components is unchecked first) and then click the reuse button.  So long as you already have an exploded view for that sub-assembly, everything should work just fine.
