Federal Pioneer USD Relay - SKM Library File
Does anyone out there have a SKM library file for the old solid state Federal Pioneer USD relay?
If so would you mind sharing it. I've contacted SKM to no avail searching for the file. If the need be I can whip one up myself in SKM. Just wanted to check if someone out there already had a made up file. No need to reinvent the wheel.
Elmir
Elmir
RE: Federal Pioneer USD Relay - SKM Library File
I also found that I had a better understanding of the device if I took the time to enter the model into the library myself. Found a number of errors and inconsistencies in the manufacturer provided trip curves over the time I spent putting things into the library.
