Child view not updating
If I change a views scale, the associated section or projection views don't change. Are they supposed to? Is there a setting somewhere?
RE: Child view not updating
You have to change scale on each individual view.
It's under the "properties" option. (right click)
Check out CATBlog!
You can also multi-select views before going into properties, and change them all at once.
-Bjorn D
Why would there be? It's not mandatory to do all projected views in the same scale...
Check out CATBlog!
Just thought that with the knowledge build into the software, it may be an option.
By doing like this all views update with a change of global scale. Child views like sections is updated with the parent view.
Check out CATBlog!
