All line coordinates to zero
All line coordinates to Z=zero.
I know this comes up fairly frequently, but I guess I'm missing it in my questions search. I'm at work, and we can't bring software from home, but I can get it from here, so any help is appreciated.
Thanks all-
C. Fee
Thanks all-
C. Fee
RE: All line coordinates to zero
-or-
'flatten' using the "move up & back" method;
Command: move
Select objects: Specify opposite corner: xx found
Select objects: Specify base point or displacement: 0,0,1e99
Specify second point of displacement or <use first point as displacement>: <enter>
Command:
MOVE
Select objects: p
xxx found
Select objects: <enter>
Specify base point or displacement: 0,0,-1e99
Specify second point of displacement or <use first point as displacement>:<enter>
ht
Lothar
ADT 2004
ACAD 2002
