DWG Editor Crashing Issue
Hello!
I'm having a semi major problem with DWG editor (2006 SP1.0)...
In most cases, when I open up a .dwg file (created with all realeases of ACAD from R14 up to 2006) through DWG editor directly, the program crashes and shuts down.
If I open the same files from Windows Explorer they open up with no problem (or at least none that I have found so far).
Any suggestions?
Thanks!!
RE: DWG Editor Crashing Issue
Try repair or modify of DWG install otherwise contact your VAR.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
