Center marks on a polygon
How can I insert a center mark on a polygon?
Thanks in advance!
RE: Center marks on a polygon
Dear c2sox;
Using SW2006, I just used sketch to place a polygon in my drawing and then used insert, annotations, center mark and clicked on the bounding circle of the polygon. Center mark placed like it should.
Have not tried this using polygon in a part file but I think it should work just the same.
Best Regards
Adrian Dunevein
www.aaadrafting.com
Looks like I'm out of luck SW2005 doesn't give me the option to select "the bounding circle of the polygon"
Show the sketch used to create the polygon, use the bounding circle to place the centre mark, then hide the sketch.
cheers
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
