Features from family table part to generic.
I have a part which has a family table part.
I made some changes in the relative part not in the generic and those changes does not reflect in the generic part.
How can I reflect the changes did in the relative part to the generic?
RE: Features from family table part to generic.
The generic model is in the first row in the table. The table entries belonging to the generic can be changed only by modifying the actual part, suppressing, or resuming features; you cannot change the generic model by editing its entries in the Family Table.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
o
_`\(,_
(_)/ (_)
"Coming together is a beginning, staying together is progress, and working together is success." - Henry Ford
Yep, but ... If you open a family member and add a feature you should find that the feature has been added to the generic and suppressed in it and all other family members. (Or so it seems to work in WF2)
In a nutshell, adding features to the generic model, will cuase those features to show up on all the instances.
Adding features to an instance, will cuase those features to be active in the instance, and suppressed in all other instances, plus the generic.
Simply resume suppressed features and select Y or N or * as needed to have them show up in all or selected instances.
Steve
http://www.sprdesign.com
http://www.3dlogix.com
Sorry to bring this topic up again, I have been off on vacation.
If you only have a generic and one family table item, you can inside the family table choose edit from the menu and pick copy instance to generic.
I also have a setting in my model tree config file (mdl_tree_cfg_file) to show suppressed items in the generic all the time. Then like 3dlogix states you can resume and suppress from the model tree in the generic state.
Tofflemire
