Hurco vs. Mazak
Hurco vs. Mazak
Hi I'm new to this board and need help with info on the pro's and con's of these two types of machine builders.
I'm consulting at this new start-up company and I've been butting heads with a guy that was hired to decide on which machines to purchase.
The machines in question are the Nexus 510 VMC, Nexus Quick-Turn 250,
And the Hurco's VMX and the TM6 or 8.
Thank you for your help.
Andrew Grossi
Andrew Grossi
RE: Hurco vs. Mazak
RE: Hurco vs. Mazak
I feel that the Mazaks are superior to the Hurcos and that's why we're disagreeing.
I just need to find out more info from people that have used Hurcos bad or good.
Andrew
RE: Hurco vs. Mazak
The machine is better built. Remember a machine is only as good as the people running it. Good luck. Harrya
RE: Hurco vs. Mazak
The prime concern of any equipment purchase is the budget.
There is no comparison between the Hurco and the Mazak. Would you compare a Honda Civic to a Lexus ?
Again almost everything depends on your budget, how many shifts are you running , what is your ROI, are you going to lease the piece of equipment?
Identify your constraints, then decide on the machine.
If you need more feedback on the Hurco try visiting the mmsonline forums.
-vhs
RE: Hurco vs. Mazak
