marking steel for galvanizing
Hi all,
How can I permanently mark structural steel that has to go through galvanizing process. I tried using die punch to mark the steels but the galvanize process usually covers parts of the marks, rendering it unreadable.
I read about embossing, or using steel tag. How do they work and are they costly?
Thank you
Thank you
RE: marking steel for galvanizing
Many who build with structrual steel apply marking by welding a bead in the numeral shape before coating. Some structural steel has imprints created during rolling.
I'm not certain about a "die punch" but we have imprinted plate with an embossing die for 3/8" figures and had them turn out okay. Secret seemed to be keeping the stamped face vertical to allow excess to flow off instead of having it fill the imprint.
Griffy
-vhs
