Failure Mode of Quick Disonnect
I have a 4000 psi quick-disconnect that ejected the plug. It may have been subjected to higher pressures than 4000 psi. Does anyone know if quick-disconnects will first rupture or will it fail to hold the mating fitting when subjected to excessive pressure?
RE: Failure Mode of Quick Disonnect
