Automatic Ceramic Surface Inspection Tool
I'm looking for an automated inspection tool to check for cracks and edge chip off for ceramic plate. Any recommadation?
Thanks.
RE: Automatic Ceramic Surface Inspection Tool
A Vision System is the first thing that comes to mind.  Cognex is the industry leader.
http://www.cognex.com/
For chips, vision sounds like a good way to go.
For cracks and internal defects a sonic system my be good.  If your parts are all the exact same size and shape you can just measure the resonant frequency and compare to a ref. part.  I have seen the systems, but can't remember the name right now.
Corrosion, every where, all the time.
Manage it or it will manage you.
http://www.trent-tube.com/contact/Tech_Assist.cfm
Here is a report that I ran across from ONRL.  You might also want to check their website, Ceramic Technology for further information.
Peter J. Blau, Rebecca L. Martin, and Laura Riester, "A Comparison of Several Surface Finish Measurement Methods as Applied to Ground Ceramic and Metal Surfaces," Ceramic Technology Project Report ORNL/M-4924, January 1996.
