barge design /drawings 1000 -5000 TONS
COULD SOMEONE ASSIST WITH DESIGN PERIEMTERS /DRAWINGS 4 RESERVIOUR TANKS OF 1000 TO 5000 TONS CARRYING FLUIDS
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
barge design /drawings 1000 -5000 TONSbarge design /drawings 1000 -5000 TONS(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: barge design /drawings 1000 -5000 TONS
This same principle applies to the stability of waterborne vessels and it can be calculated. If you don't know how to calculate the metacentric height of a vessel and how to take deductions from the metacentric height for free surface effect you are asking for a disaster. Barges look deceptively stable but when they flip they flip with lightning speed. Contact a Naval Architect or a Civil Engineer with experience in this area. Naval Architects are not architects they are actually a type of Mechanical Engineer. They have knowledge which is critical to your project. Beware though as in any field of engineering there is the occaisional idiot. Check references.
You need to be able to calculate KG (distance from the keel to the center of gravity of the combined vessel and cargo) KM (keel to metacenter) GM (center of gravity to metacenter) plus the free surface effect of the liquid which is also a metacentric height which is deducted from the vessels metacenter but it is not a straight process of subtraction.
Stucturally the vessel needs to be strong enough so that it can be supported on the crest of a wave with both ends in the air and also with each end supported on a wave with the center up in the air. But that part is easy.
DPA
