NEED SIMULATION INFO
I'm retired and am requesting a favor from one of you guys who has access to chassis simulation software. I'd like to know the ratio of right front spring rate to left front spring rate, for a beam axle RWD car, that will provide cancellation of the driveshaft torque. Obviously, many parameters are involved, but I'd like a ballpark figure for an "average" car. Yes, I realize that asymmetric rear suspension links would provide a much better solution, but, if the ratio is reasonable, this would be a quick and dirty solution for the dragracer who either has adjustable coilovers or...as in the Chrysler products...has a torsion bar adjustment. Please keep the sum of the spring rates constant. Thanks in advance.
RE: NEED SIMULATION INFO
I'm struggling with the free body diagram of this, I can't see how to cancel the roll (if that's what you want) due to torque on the back of the gearbox by changing the front spring rates.
Cheers
Greg Locock
Greg, the goal is to equalize rear tire loadings, during launch, to maximize tire traction. If the right front spring has a higher rate than the left front, the LF corner will rise higher than the RF, meaning the RR will be forced down, tending to cancel driveshaft torque effects and equalize rear tire loading.
Oh OK, I didn't know what you wanted to cancel. Do you want equal rear springs?
Cheers
Greg Locock
Yes, equal rear spring rates. Thanks, Greg.
Are you expecting a different result from the first couple of chapters in Gillespie?
Cheers
Greg Locock
Don't have Gillespie. Have RCVD (used it as a text when teaching), but it doesn't seem to be of any direct help.
I realize that the reaction torque is distributed, front-to-rear, in proportion to the roll stiffness, so that which I fear is that the required rate ratio would be infinite, since only that would mean zero front roll stiffness. But, the problem is sufficiently "cloudy" that I hope I'm wrong and that a reasonable ratio will be found. Certainly, if the problem is simplified to the point that the fronts are assumed to rise equally (no twisting of the chassis), the ratio can be easily found and is quite reasonable. Intuitively, the idea seems to be a "slam dunk." The sum of the right side loads must remain equal, so, with a high rate spring at the right front, this would mean the majority of the weight transfer would be going to the right rear. But, my intuition has gotten me into trouble so many times in the past that I no longer trust it.
Hey Billy, as I think you expected there is no general solution. You can tune the corner weights so that at one particular torque the rear wheel weights are equal, but it won't work for all torques.
That's from a 3d model, I'll look at the free body diagram again, just to make sure.
Cheers
Greg Locock
No, I'm not after a static preload. If the front spring RATES are different, the effect will be dynamic and the cancellation...either full or partial...will be equally effective for all values of driveshaft torque. Same situation as with asymmetric trailing links at the rear.
Yes, that's what I'd thought you wanted, but using my model I couldn't find a solution that did that. It could be a modelling problem as it wasn't the best model I've ever knocked together.
Cheers
Greg Locock
I thought you'd have a "plug and crank" at your place of work. I'll try and model it myself. If you have a personal interest, I'd appreciate your verification of my results. If not, thanks for your interest to this point.
I do have a plug and go model, but to be honest I've got enough work to do at work, without doing odd jobs on the side!
Cheers
Greg Locock
I understand. I'm retired, so it's a little different. Thanks, anyway.
I should have a solution to post later today.
I'm pretty certain that, for complete driveshaft torque cancellation, the ratio of RF wheel rate to LF wheel rate should be equal to the ratio of (1 + Z) to (1 - Z) where "Z" is the fraction of the total roll stiffness at the front. So, complete cancellation might be impractical for a "street" car, but, for something like a long wheelbase dragster, it would appear desirable to try some sort of suspension on the LF only.
Certainly, the ease with which the effectiveness of such a scheme can be tested in the shop...using d'Alembert's Principle...should be considered. Simply slipping wheel scales under the front tires and observing the load changes as a horizontal chain is tensioned out the rear is a worthwhile test.
Billy,
     I recently went through the painstaking process of writing out long hand expression for all of the dynamic load transfer components on my type of racecar.  I have a live axle @ the rear w/ a torque tube, and a solid axle up front.  I think most drag cars probably have independent front, but adapting my expressions is just as simple as making front spring rates = front wheel rates, and front spring width = front track width.  When I do that, in order to get the cancellation that you speak of, I get a somewhat different expression than you:
K_R/L = ratio of RF to LF wheel rate
      = N/D
N = %FRS + %RRS*(t_f/2)*(h_cg/L)*(eta/R_L)
D = %RRS*(t_f/2)*(h_cg/L)*(eta/R_L) - %FRS
%FRS = your "Z" value
%RRS = fraction of total roll stiffnes @ the rear
t_f  = front track width between contact patch centers
h_cg = CG height from grd.
L    = wheel base
eta  = torque multiplier between where the driveshaft pivots
       on the vehicle and the rear wheels (rear end ratio
       usually)
R_L  = rear tires loaded radius (assumed = side to side
       which is actually true if the tires are loaded
       equally)
     The %FRS terms come from the engine torque compenent of load transfer, and all that other junk has to do with the fact that asymmetric spring rates @ the front will cause the car to roll whenever it is required to pitch, which will transfer load across through the rear roll stiffness.
     My confidence in these expressions is probably 70% as it is easy to make a mistake when doing that much algebra by hand, but it's up for discussion now anyway.
You're probably correct. I realized, after I had posted, that the axle ratio had been dropped somewhere in the derivation and I couldn't see how that could possibly happen. Yes, the algebraic manipulation can give one a headache. As I indicated, the matter could be settled with a relatively simple test setup, but I'm retired and no longer have the space or even access to wheel scales. I've tried to get local hotrod shops interested, but, when I start talking about pulling backward with a chain while the front wheels are on wheel scales, they quickly conclude I'm just another senile old man.
     Well, most people wouldn't classify me as old just yet, so in my case, it's just another senile engineer.
Billy,
You might try a little trick we use on roundy round cars and use rebound adjustable front shocks and set the LF with MORE rebound than RF. The weight will transfer to the LR more quickly than the RR and you can tune it with the twist of a knob.
Wayne Malmstrom
There is no meaningful weight transfer in automobiles unless there is significant roll or pitch angles (or movable ballast, as in the old DTM racecars). I suspect you mean load transfer. How does adjustable damping change the load transfer?
Best regards,
Matthew Ian Loew
Transitionally, by affecting the velocity-sensitive components of load transfer.  No help once you get to steady-state, though.
Norm
I would have to disaree about no weight tranfer, after 35 years of racing cars, there is very significant weight transfer, do to roll center location in vertical and lateral location, front to rear,relative to the center of gravity.
With shocks your are controlling how fast it happens and where it is going first.
At this point in time shock packages are the most crucial adjustments you can make for transitional responses.
And in our form of racing, the getting into and getting off the corner is where you are gaining the most.
Okay, let's try to "common sense" this problem through to a solution.
We have a RWD, beam axle car with symmetrical suspension linkage (i.e., mirrored in the XZ plane). RR and LR spring rates are equal. And, we'll start with RF and LF spring rates also equal. Although it doesn't affect the final outcome, we'll assume 100% anti-squat, just to make it a bit easier to visualize. We'll assume that 2/3 of the total roll stiffness is at the front.
On launch, driveshaft torque tends to unload the RR tire (and, of course, load the LR). The reaction to that driveshaft torque tries to prevent this unloading, but, with 2/3 of the roll stiffness at the front, only 1/3 of the necessary reaction torque is fed back to the rear axle assembly through the rear suspension springs.
With the right rear spring being compressed, there is necessarily a lifting of the left front of the car relative to the right front.  If full cancellation of the driveshaft torque is to be realized, the sum of the jounce of the RR and the rebound of the LR must be tripled, meaning that the same deflection multiplier must be used at the front. Since the anti-squat removes the opportunity to use the rear springs to achieve cancellation, efforts must be directed to the front.
But, here's where it gets really interesting! Since the rear wheel loadings are to be equal, that means the front loadings will also remain equal. Since they remain equal, the front springs cannot contribute to the front roll stiffness and that 2/3 figure originally assumed becomes meaningless. Yet, somehow, that right rear of the car has to come down to load that right rear tire, through the suspension spring, and cancel the driveshaft torque.
The task is left, then, to the front swaybar. It must provide all of the resistance to the driveshaft torque WITHOUT affecting front wheel loadings. This can be done with the proper relationship between front spring rates and front swaybar rate. I ended up with the following relationship:
    (KR - KL)/(KR*KL) = 2*L*R/(H*X*KB)
Where "KR" is the RF spring rate, "KL" the LF spring rate, "L" the wheelbase, "R" the effective rear tire radius, "H" the CG height, "X" the axle ratio, and "KB" the sway bar rate (using the deflections at the tire).
As would be expected, the difference between LF and RF spring rates becomes infinite as the sway bar rate goes to zero.
Arrgh! How can I be so stupid? Don't answer that! I lost my "common sense" half way through that analysis. I turn 70 in eleven days and my only excuse is my obvious senility.
Okay, the right rear of the chassis has to come down. This will happen with a symmetrical setup, but the roll resistance at the front takes up some of the reaction torque so the driveshaft torque isn't completely cancelled. The front roll stiffness is from the suspension springs and the sway bar. What is needed is enough chassis deflection to completely cancel the driveshaft torque, but, at the same time, the front loadings must remain equal. So, at the rear, the rear roll rate and the driveshaft torque determine the necessary chassis angle. All that's necessary, then, is to achieve that angle without, again, upsetting the front.
The solution is simply to get rid of that pesky front sway bar entirely and then adjust the spring rates, at the front, so that the front tire loads are equal with that necessary deflection. (The problem is really very simple, but it's taken a long time for this tired old brain to "see" it.)
The solution is similar...in appearance...to that in my last post:
   (KR -KL)/(KR*KL) = 2*L*R*T/(H*X*Kr)
Where "Kr" is the rear roll rate and "T" is the front track.
Now, I'll go take my medicine and return to bed.
85Chief,
Please re-read my comment. I am distinguishing between weight (mass * acceleration due to gravity) and load. Assuming g is constant, weight is directly proportional to the mass. Mass is NOT being transferred (unless there is movable ballast). Load is being transferred by the lateral and longitudinal accelerations of the sprung mass (and the torque reactions, as well). Anti-dive, anti-lift, etc. all reduce the load transfer from suspension geometry.
Regarding the damping and transients, I thought the discussion was all about steady state (static) load transfer. I did not recall a discussion about transients.
Please correct me if I am wrong on this part.
Best regards,
Matthew Ian Loew
Sorry. Those have to be WHEEL rates, not spring rates.
(I had started with the assumption that I'd end up with a simple ratio, in which case it wouldn't have mattered.)
Billy,
     Your last expression appears very similar to my original expression which I stated I only had partial confidence in (same terms anyway)... have you tried to solve for the ratio of RF to LF wheel rate to see if it comes out the same, that would be encouraging if it we independantly arrived at the same result?  The only thing that looks appreciably different to me is that you have a 2*T factor instead of a T/2 factor,  which may come out in the wash.  One of the finer points might be chassis flex, which would probably mean that you need an even greater difference between the RF and LF wheel rate to get the effect you're looking for... which is where the rig (or track) testing would be handy.
No, bhart, can't get a simple ratio. I'm quite confident in my result, though an algebraic manipulation error is always possible. As for a practical application, it would appear that a hefty rear sway bar would be needed to keep the difference between front spring rates reasonable. Handling would be terrible, of course, but we're considering only dragstrip conditions here. By the way, that rear roll rate relates to radians, not degrees.
Bhart, here's the equation set with which I started. I hope we agree to this point:
Driveshaft torque = N*L*R/(H*X)
where "N" is that which is called the "weight transfer" by the dragracers.
Driveshaft torque = Kr*A
where "A" is the chassis roll angle.
A = (DL - DR)/T
Where "DL" is the left front chassis rise (measured at the wheel) and "DR" is the same for the right.
N = KL*DL + KR*DR
KL*DL = KR*DR
The remaining variables are defined in earlier posts.
Billy,
I am sorry, I thought it was a discussion in what  really happens, not an exercise for the mind.
You know nothing is static at the hit of the throttle.
Have a nice day
