problem with open file/insert componet dialog box
When I open a file or insert a component the following dialog box (the one where you select which component to open or insert) never displays the files in an alphabetical or numerical order anymore. I have to right click and arrange icons by name. It is just through SW when I navigate to the file locations on our sever through "my computer" they are displayed in an alphabetical and numerical order. Is there possibly a setting I have unchecked? Thanks.
Grant
Applications Engineer
SW2006 SP 0
IBM InteliStation Pro M
P4 3.4 GHz, 2GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1100
RE: problem with open file/insert componet dialog box
Grant
SW2006 SP 2.0
P4 3.4 GHz, 2GB RAM
XP Pro SP2.0
Grant
SW2006 SP 2.0
P4 3.4 GHz, 2GB RAM
XP Pro SP2.0
SW only lists the files per the windows settings.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Flores
SW06 SP2.0
Looking at the Solidworks forum under interface, it looks like this has been addressed in 2007.
Jason
UG NX2.02.2 on Win2000 SP3
SolidWorks 2005 SP5.0 on WinXP SP2
SolidWorks 2006 SP1.0 on WinXP SP2
It's only seemed to happen just recently. We're switching to a new server BUT out of 4 SW seats I'm the only one to see this problem. I've contacted my VAR but no response yet. I'm hoping when we go to SP 2.1 that will fix the problem.
Grant
SW2006 SP 2.0
P4 3.4 GHz, 2GB RAM
XP Pro SP2.0
