Manufacture of a structural 'ladderframe' dry sump
I'm looking at the feasibility of designing a new, structural, ladder-frame type dry sump to fit to an existing in-line 4 cylinder engine. By structural I mean the transfer of loads from gearbox to monocoque, similar to a Formula 3 concept. Currently I'm considering machining the sump from solid.
I'm worried about the machining processes required to match the new sump to the existing block, particularly main bearings and cap bolts.
Any help / advice or pointers to good references will be appreciated.
Regards, Ian
Regards, Ian
RE: Manufacture of a structural 'ladderframe' dry sump
