Sectioning a Product Model
I can't seem to figure out how to section a Product model, so that I can create snapshots for a proposal.
RE: Sectioning a Product Model
Use the "sectioning" tool.
If you aren't sure what it is, type c:Sectioning in the whitespace at the bottom, and watch to see which icon lights up.
Check out CATBlog!
Have you chosen to ouput the section as a volume?
Check out CATBlog!
Several possibilities are:
A volumetric section cut (part physically cut)
Wireframe only (no part cut)
output of wireframe sections as neutral file format (iges)
After using "sectioning," you should have an object in the tree called "Applications", and under it, should be another called "Sections." Your sections should be visible as long as this object exists in the tree.
Make sure that your section is actually cutting the part, of course.
Check out CATBlog!
I've noticed that a section appears under "Applications" while I am in the sectioning command, but dissapears once I select OK.
Is there a bug in R14 that does not allow this to work?
I want to be able to create a section through my assembly and then create snapshot images, assembly parts while sectioned, etc.
