Returning leadscrew-Same direction rotation
Hello all, I'm looking for a solution to lay cable on a drum at a fixed rate. The problem being that the motor on the leadscrew will always be in one direction. Is there a standard part (leadscrew) that has a full helical loop that a hub could follow?
My company have used them in the past but no-one can find the old supplier.
Basic dims would be Dia 10-15mm (3/8"-5/8"), 250mm (10") travel. Helix to be confirmed.
Might I note we're in the UK.
Cheers all
Mark
Cheers all
Mark
RE: Returning leadscrew-Same direction rotation
bobc
http://www.norcoinc.com/
http://www.kedacorp.com/cylindrical%20cams.htm
